Hi all
I am trying to convert a 3 channel colour organ into a 4 channel one. Please see the pic.
All I want to do is to split the existing midrange channel into 2, without affecting the low and high channels. I have added in another channel.
1. Could you please help with the RC values for this?
2. On low and midrange1 channel, I will be driving 4 Red and 4 Green leds each (total of 20mA). On the midrange2 channel, 6 Blue leds (total of 40mA) and on the high channel, 8 White leds (total of 80mA). Do I need to change the base resistors of the transistors? If so, to what? The supply voltage is 12v.
3. The audio input is "line level". Where do I find this? I would like to use the speaker outputs directlly. Do I need an attenuator circuit? Can you provide me with a schematic please?
Thank you for any help I may receive.
Max
Max
