conversion of 220V 50Hz to 26/28/115V 400Hz
Discussion in 'Homework Help' started by dlamz2000, May 19, 2012.
  1. dlamz2000
    May 19, 2012
    Please I need someone to help me with a circuit I can use to supply a 26/28/115V 400Hz supply from 220V 50Hz. I need it for my school project. Thanks a million.:confused:
  2. crutschow
    Mar 14, 2008
    13,481
    3,368
    The usual question. How much power do you need from these outputs?
    dlamz2000 likes this.
  3. Bernard
    Aug 7, 2008
    4,236
    414
    It would operate just like a switching power supply- 90 to 240 V AC 50-60Hz input with a 400Hz oscillator & thin steel lamination transformer. Sorry no ckts as this involves high V before the transformer [ bridge rectifier, MOV, fuse, & filter cap].
  4. dlamz2000
    May 19, 2012
    Crutschow and Bernard, Thanks a lot for your reply. I would love to supply a load of 25amp. My supply will be from a 220V 50Hz generator. I'd seriously need help here because we dont do design in my school. I just want to do something new.
  5. MrChips
    Oct 2, 2009
    12,624
    3,451
    Are you planning on building this?
    If so then this is not appropriate for a school project.
  6. dlamz2000
    May 19, 2012
    Yes I want to build that. I may not go miniature. Hoping to achieve it using normal electronics (Transistors, capacitors, resistors...) and a transformer or so. To make any reasonable impact at times costs a lot. I am willing to give it a try. Can you asist?
  7. Bernard
    Aug 7, 2008
    4,236
    414
    25A doesn't help with out knowing at which voltage it refers to- or did you mean 25 W ? Some speculation: If 700 W required, @ 60 Hz, core would be around 10 pounds, an audio or ferrite core then might 10 X 60 / 400 = 1.5 lb. Time for me to drop out as this is high V, & I have no experience building a hi V oscillator.
