conversion from single cycle to multicycle
Discussion in 'Homework Help' started by GipsyDanger, Dec 12, 2013.
  1. GipsyDanger
    Dec 12, 2013
    hello again
    i wanna ask how to convert a single cycle MIPS code to multicycle
    i dont have any idea to do this
    for example, MIPS code
    Code ( (Unknown Language)):
    1. .data 0x10010000
    2. prompt1:    .asciiz "Insert an integer: "
    3. prompt2:    .asciiz "Insert number of loops: "
    4.         .text
    5. .globl main
    6.
    7. main:   # preparation
    8. addu $s0, $ra, $0       # save $31 in $16
    9.
    10.         # input x
    11.         la $a0,prompt1              # print string
    12. li $v0,4                # service 4
    13. syscall
    14.
    15. li $v0,5                # read int into $v0 (x)
    16.         syscall                 # service 5
    17.         move $t3, $v0           # move x to $t3
    18.
    19.         # input p
    20.         la $a0,prompt2              # print string
    21. li $v0,4                # service 4
    22. syscall
    23.
    24. li $v0,5                # read int into $v0 (p)
    25. syscall                 # service 5
    26.         move $t1, $v0           # move p to $t1
    27.
    28.         # prepare counter (a)
    29. li $t0, 0
    30.
    31.         # prepare multiplier
    32. li $t2, -2              # looping
    33.
    34. loop :  bge $t0, $t1, ended
    35.         mult $t3, $t2
    36.         mflo $t3
    37.         addi $t0, $t0, 1
    38. j loop
    39.
    40. ended :     # print result
    41. move $a0, $t3
    42. li $v0,1
    43.         syscall
    44.
    45.         # ending
    46.         addu $ra, $0, $s0       # return address back in $31
    47.         jr $ra                  # return from main
    48.
    this code is a code to compute the value of a using recursion and wont stop until a value is same with other value.
    The question is how do i convert them to multicycle?
    and what about if different code is used?
    please help me
    best regards
  2. WBahn
    Mar 31, 2012
    18,089
    4,917
    Usually, single-cycle and multicycle refer to the processor architecture and not the program running on that processor.
    Are you using Patterson and Hennessey? If so, which edition? If you can, get yourself a 1st or 2nd edition -- they are pretty cheap now -- as they are much better than later editions.
