conversion from dB
Discussion in 'Homework Help' started by u-will-neva-no, Jan 11, 2012.
  1. u-will-neva-no
    Mar 22, 2011
    230
    Hello everyone,
    there should be a relatively easy solution to this but I can't get the correct answer.
     20\log_1_0(x) = 20dB
    How do I find x?
    I try to rearrange (taking the exponential of both sides but that does not work). Am I suppost to change the RHS (20dB)?
  2. joeyd999
    Jun 6, 2011
    2,757
    2,936
    how about divide by 20 first?
  3. Jony130
    Feb 17, 2009
    3,993
    1,116
    First step
     \frac{20dB}{20} = 1
    Second step
    10^1 = 10
    So the x = 10
    for 25dB
     \frac{25dB}{20} = 1.25
    10^{1.25} = 17.7827941
    u-will-neva-no likes this.
  4. thatoneguy
    Feb 19, 2009
    6,357
    718
    Wiki covers it well
    The part where people get caught up is when to use 10 log or 20 log for dB. When measuring voltage or current gain, use 20 log, when measuring power gain, use 10 log.
    It is also good to remember the conversion for dB/Octave <-> dB/Decade (left as an exercise for student)
  5. u-will-neva-no
    Mar 22, 2011
    230
    Brilliant, thank you Jony130 and thatoneguy !! :)
