Conversion between pic18f458 and pic16f690 with xc8 function tables
Discussion in 'Embedded Systems and Microcontrollers' started by johnnyinwa, May 15, 2015.
  1. johnnyinwa
    Jun 24, 2013
    41
    Heh Guys,
    I am using the microchip XC8 C compiler (free version) with the MPLABX IDE on windows VISTA.
    I had three questions for converting pic18f458 code to pic16f690 code:
    Question #1 -- TRISD=0 and TRISbits.TRISD=0 -- What is the correct syntax for the pic16f690?
    Question #2 -- LATD=0b10101010 and LATDbits.LATD0=1 -- What is the correct syntax for the pic16f690?
    Question #3 -- if (PORTDbits.RD0==1) Return; What is the correct syntax for the pic16f690?
    Question number one sets a port or a bit to output or input.
    Question number two writes to a port or a bit.
    Question number three reads the status of a pin on a port.
    I have attached a three page table of all the XC8 library functions for your use. Some of the explanations are inexact but they fit on the table. Thanks for your help. ;
  2. ErnieM
    Apr 24, 2011
    7,435
    1,625
    Givens: PIC16F690, XC8 compiler
    Question #1: set a port or a bit to output or input.
    That is two different questions with two different answers. The former is correct for the whole port, the latter incorrect for the bit.
    For a bit you need to specify WHICH bit, say TRISbits.TRISD0 = 0;
    However, the PIC16F690 does not have a port D so you need to stick to one of the three ports it does have.
    Question #2: write to a port or a bit.
    Neither. The latch is not the port, and the PIC16 series does not have the latch, it just has a port.
    Now in the PIC18 series the latch and port instructions do indeed write to the same register, but they read different things; latch reads the register directly, while port reads the pin state associated with the latch.
    That would be correct IF this device had a Port D.
