Hi Guys,
I'm new to embedded design and I just want to discuss the concept of conventional process a designer would take from start(picking a new micro) to finish (micro on PCB with implemented algorithms and functions).
Lets start of with my situation: I am currently starting an "improvement" project of a previously designed embedded system and one of the improvements I want to implement is the replacement of the current mico ( http://www.digikey.ca/product-detail/en/CY8C27443-24SXI/428-1598-ND/679709 ) , a Cypress chip, to an NXP ARM based chip ( http://www.nxp.com/products/microcontrollers/cortex_m0_m0/lpc1100/LPC11C24FBD48.html#overview ). I chose this chip because its ARM based, and it has SPI , CAN functionalities and its cheaper.
I have never experienced this before and would like to hear input.
How much would buying the dev kit of the new chip help me? I think that when the time comes to just buying the chip and installing/implementing on PCB board, I would start at zero again and make my own libraries and protocols to use SPI and CAN. Also, how would programming the chip and running my algorithms (ie. main functionalities) be different?
Thanks,
MrBuggy
Thanks,
MrBuggy
