Controlling solenoid valve
Discussion in 'General Electronics Chat' started by Siddha05, Jun 2, 2013.
  1. Siddha05
    Jun 2, 2013
    Folks...Noob here...need help from all your experts out there for a similar setup. I need help with making the connections for controlling a normally closed 12VDC solenoid pinch valve using a DAQ Card with Digital Output (NI USB 6009), SSR (LCA 710) and a DC power supply [ZP40-51212N]. The SSR has 6 pins (3 on each side). Can someone tell me what should I connect on the control side and the load side. Thank you very much.
  2. Georacer
    Nov 25, 2009
    5,151
    1,266
    Your post was moved into its own thread, since this is a separate question.
    Please open a new thread each time you want to ask a new question.
  3. Uber_Goober
    Member
    Jan 19, 2013
    45
    I'm not familiar with the DAQ card but I did recently do a project where I'm controlling a 12VDC solenoid valve from a PIC microcontroller. I'm driving the PIC with a digital MOSFET and it works very well.
    Here's the mosfet I'm using:
    http://www.digikey.com/product-detail/en/DMG1012UW-7/DMG1012UW-7DICT-ND/2183242
    Just don't forget to put a flyback diode across the coils.
    Here's the circuit I used in case it helps. Note that the pin connectors "c1" and "c2" are for a header on my pcb. The solenoid has a female header that plugs in here.
  4. crutschow
    Mar 14, 2008
    13,501
    3,375
    Why do you need the SSR?
