I have a basic heater,which has only two options-ON and OFF.
I want the heater to work only between two set temperatures,L and H.
I came across the age old Wheatstone bridge to measure unknown resistance.
Can a modification of this idea be used to get one, I am looking for?
Here is my thinking.Replace two 'arms' of the bridge by LM35,with the output being joined to the middle of the other two 'arms'. These two arms form a voltage divider. Adjust two resistances so that the output voltage matches with the voltage output of LM35 at ,say L .Depending upon the LM35 temperature, there will be current in one or other direction, when it becomes unbalanced. Use this to trigger, using NPN transistor, to start or shut off the heater. One would need to use 555 for latching.
I did try to get unbalance Wheatstone bridge with LM35 as two arms,using .220V=L and I could get voltage at the middle.But I couldn't get LED to glow.I am using BC547 and diagram is as follows:
Presently temperature is at 22c so I have adjusted R1 and R2 so that ratio is above 220. There is current toward LM35. My non knowledge of fixing R3 is probably(the charitable!) is reason.The other is --- it is not a workable sketch!
Please opine.
suresh paranjape
Please opine.
suresh paranjape
