Controlling multiple (10+) DC motors at once... HELP !
Discussion in 'General Electronics Chat' started by sheffladreece, Jan 22, 2014.
  1. sheffladreece
    Jan 22, 2014
    9
    New to the forum first off let me say hi to you all, and i look forward to hearing any solutions, suggestions and or advice that you may have regarding my problems here on.
    Firstly very very basic knowledge of circuitry... Although more than capable of learning new concepts quickly.
    The issue I am having is devising a way in which to control multiple DC motors WIRELESSLY i.e. basically just turning them on and off and nothing other!
    Suggestions/ solutions regarding this issue please
    Sheffladreece
  2. shteii01
    Feb 19, 2010
    3,516
    515
    Transmitter for the operator.
    Each motor has its own driver circuit. The driver circuit is connected to the receiver. Receiver generates ON/OFF signal based on the signal from transmitter.
  3. MaxHeadRoom
    Jul 18, 2013
    10,860
    2,525
    I have used a TX/RX pair with a decoder IC RWS-434 TWS-434 and CIP-8E and CIP-8D decoder, this is older technology, but there should be modern equivalents.
    This set up was for 8 operators.
    Max.
  4. sheffladreece
    Jan 22, 2014
    9
    How small can the receivers be ? and would it be possible to get one for under a £1 ?
    How small can the transmitters be? and would it be possible to get one for under £5 ?
  5. MaxHeadRoom
    Jul 18, 2013
    10,860
    2,525
    What range do you want, you most likely can get something from the simple R/C sites that is multi-channel fairly cheap?
    Max.
  6. sheffladreece
    Jan 22, 2014
    9
    Im hoping to achieve around a 30m x 30m x 10m (l x w x h) range if that is at all possible ?
