I need to be able to control a signal that ranges from 0-~6V with a 5V micro output. It used to be controlled with a PNP but this is no longer feasible since the signal now will potentially exceed Vbe even with 5V micro output.
Relays aren't really an option since they are far too slow and expensive. I'm looking for a surface mount alternative, preferably analog. The switch is only on for 2 ms so relays turn on times of >0.5ms is far too long.
I have access to a 5V rail, a ~8.25V, and a line that is anywhere between 8-24V.
Help?
Thanks,
Bob
Help?
Thanks,
Bob
