Hello guys,
I have a question which I think would be easier to explain using the drawing I have attached.
My problem is that in the mesh/grid I want current in branch B & C by giving corresponding supply as shown. However I don;t want the current in branch A, D, E etc. Since these branches form a parallel path current is obviously going to flow through them. Is there any way I can restrict it?
I think I can use mosfets or bjt between those nodes but I want to keep system as simple as possible & I think there can be a way to restrict the current without using any external devices.
Thank you.
Thank you.
