controlling array of leds from hex keypad
Discussion in 'Embedded Systems and Microcontrollers' started by chaudhryali, Jan 17, 2011.
Thread Status:
Not open for further replies.
  1. chaudhryali
    Jan 14, 2011
    hi!
    m new to this microcontroller programming and i need a help of how to control an array of led ..it is in programmer board,and m using mplab hi tech c compiler and ponyprog to burn it into the pic.
    so all i need is that how can i write a c program to switch between led's that i want .for example from the hex keypad i press 1,when 1 is pressed the 1st led should be on and other led's should remain off..hex-keypad is included in my project.only i want to know how control individual led on the board..means the c program ...thanks in advance
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
Thread Status:
