Hello Everyone.
I am a newcomer to this forum. I tried to look around different discussions, but couldn't find one which could be of help on my specific subject.
I am a total novice at electronics, however, I have managed to assemble a few functional DIY circuits using semantics and part lists from the web and assembling these circuits for my personal usage on bread boards... so I can safely say that I can follow instructions and guidance if clearly provided.
I am also an absolute novice at computer programing, except for one odd experience where I tried to use a notebook computer to drive a stepper motor using the computer's printer port and a small circuit on a bread board, while passing the instructions to the board using a downloaded free software.
I am a semi pro photographer and like to do a lot of DIY stuff to be used in my photography, and have recently been trying to build a water drip system that can be controlled precisely to the millisecond.
I am trying to look for a way to control a Solenoid Valve using a Windows XP notebook through its Parallel (printer) or Serial port. (I am not sure if Windows 7 and a USB connection would be capable of doing this or not, hence my selection of an old XP notebook which has serial and printer ports built in)
To achieve this, I believe that I would be needing a software script in basic or some other language, a connection between the computer and a circuit board (a bread board in my case), perhaps one or two timer and other IC's and a few other electronic components, which would finally connect to a Solenoid valve on one end and a power supply on the other.
My usage objective is as follows:
1. There would be a liquid storage source which will be connected to the Solenoid Valve. The storage source would provide a consistent flow/pressure of water/liquid to the valve (Mariotte Siphon).
2. The software/circuit needs to be assembled in such a way that I can send instructions to the Valve on, When to open, how long to open, how long to remain closed and when to open again and for how long.... and this turning into a repeated series of events, until the program instructs the valve to stop and stay closed.
3. The duration of each event, needs to be in milliseconds or finer if possible.
What I know so far, is that I can possibly grab a solenoid valve from our local electronics component market. Most likely, I would be able to get one which can operate on a 12 volt battery (alternatively, I believe I can also power the solenoid valve using a 220v AC to 12 volt DC power adapter... please correct me here if I am wrong)
I genuinely seek some guidance and help, which can bring me closer to achieve the above. Any help in this respect would be very highly appreciated.
I would like to thank you all in advance.
Omer
Omer
