Controlling a solenoid valve from a computer
Discussion in 'General Electronics Chat' started by brainy19, Jul 10, 2013.
  1. brainy19
    Jul 9, 2013
    I know there has been threads that describe how to control a solenoid valve from a computer, but my understanding of electronics is rather limited unfortunately. I know a solenoid valve is electronically operated and I heard I will need a relay of sorts to do that. However, I'm not even sure what a relay is and even then, how would I be able to connect it to my computer? What sort of code do I need to learn in order to control the valve? I do have MatLab, if that helps.
    Any help is appreciated and if you need more information, please let me know.
  2. wayneh
    Sep 9, 2010
    12,368
    3,224
    If you don't mind spending a little money (~$120), you could use a data acquisition device such as the LabJack U3HV (the one I have, there are others such as DATAQ that can be cheaper). It can be controlled by just about any software you want and has a wealth of functionality. One function is outputs that you could use to control a relay or possible your solenoid directly.
    What power - voltage and current - does your solenoid require?
  3. JDT
    Feb 12, 2009
    658
    85
    Once again, what are you exactly trying to do here?
    If you don't know anything at all about electronics or computer programming it might be better to get someone else to do the job for you!
    If you want do do this as a project so that you can learn, well, I would start reading up on simple electricity, electronics and computers. Come back in a year or two and we can talk.
  4. mcgyvr
    Oct 15, 2009
    4,784
    973
    There are numerous IP/USB/RS232 relay boards out there and they typically include the software to control them.. But without more details..well thats all I can provide.
  5. brainy19
    Jul 9, 2013
    Thanks for the help guys. It sounds like by doing this project, I am biting off more than I can chew. I'll look for some books where I can learn this stuff but if you guys know of any any books or websites where I can learn this stuff effectively, I would greatly appreciate it.
  6. mcgyvr
    Oct 15, 2009
    4,784
    973
    The best book in the world is "Google"
    There is NOTHING you can't learn on google.
  7. wayneh
    Sep 9, 2010
    12,368
    3,224
    Then please look up the next powerball lottery number and let me know. ;)
  8. Austin Clark
    Dec 28, 2011
    409
    44
    The simplest thing would be to use an old computer with a parallel port, and control a transistor from that to power your solenoid. There are many parallel port programs that can be used for free, and the pinout diagram can be easily found via a google search.
