I have a servomotor (not Futaba) which looks like a DC Motor. It rotates 360 degrees.
Can you help me in programming this using Assembly language in PIC16f84?
This is the problem. I have 3 receivers, a photo diode. If the left receiver is high, the motor will turn counterclockwise, for at least 2 seconds only. After 2 seconds, the motor should stop rotating even if the left receiver is still high. Same goes with the right receiver.
How should I program this? Timers, Delays or WDT?
Thanks for any help you may extend..
