Hi all, new here so please forgive me if I don't use the correct terms. I know almost nothing about electronics but something about AC and DC electricity. With that noted, here goes. I have a 24 V DC motor that I want to make run without a motor controller if that is possible. This system was controlled by a 24V OT 301A9. Maximum current :29A motor controller. Is this controller what they call PWM?
It has two 12V batteries hooked in Series.
The charge side of the controller is good but the run side doesn't work. Motor is good..Tested by jumping directly from the battery to the motor and it runs fine. Even tested it backwards, runs but a little slower, which I assume is the nature of the beast.
I am looking for a cheap way of controlling this motor or a place where I can find a replacement motor controller and a schematic for it. All help will be greatly appreciated. Oh yes, one more note. This set up is on one of those Razor style scooters. Was given to me and I want to fix it for my Gkids. Thanks in advance. Carl
