CONTROLLING A 12VDC RELAY WITH 2VDC SOURCE USING A TRANSISTER
Discussion in 'The Projects Forum' started by KENOWITCH, May 25, 2016.
  1. KENOWITCH
    May 25, 2016
    Could someone have an idea on what to do if you want to switch on a 12vdc relay coil with a signal of 2vdc that is lighting up a certain LED? My setup is that I connect the 2vdc to the base of the transistor via a resistor and the connect 12vdc voltage source to the terminal A1 of the relay coil and then connect the the terminal A2 of the relay coil to the collector. Finally I connect the emitter to the ground and the I am done. Is this the right thing to do? Ideally what I want to achieve here is to have the relay coming on when the LED comes on and vice versa. Then I use the relay contacts either as digital inut signals for some control or to run some load e.g a lamp or a small motor. Please help.
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I think so, but verbal descriptions are sometimes hard to follow. For best results I suggest you come up with a schematic diagram. This is the universal language of electronics.
  3. MaxHeadRoom
    Jul 18, 2013
    10,837
    2,511
    Don't forget the BEMF diode across the coil.
    Also look at using a 2n7000. Mosfet.
    Max.
  4. Alec_t
    Sep 17, 2013
    5,971
    1,135
    Your circuit sounds right, except for one vital missing component. You need a reverse-biased diode connected across the relay coil to kill the nasty voltage spike which occurs when the coil switches off. Diode cathode goes to +12V, diode anode goes to collector. Whatever supplies current to the LED must also be able to supply the required transistor base current.
