I am hoping to control (dim, brighten, turn on + off) this DC 31-36V 100W (3A) LED with an Arduino.
The LED is using an AC to DC power supply that gives it the correct amount of power (output 24-36v 3000ma). I am also using a huge heat sink that means that the LED doesn't heat up much at all when in operation.
I have purchased some MOSFET transistors (these ones) to implement with the Arduino. The instructions I will be following can be found here.
My question is whether this will be appropriate to do? - whether it is safe and the correct way of controlling such a high power LED?
Suggestions and alternatives welcome, but it would be good to know if I can go ahead with this route.
Thanks!
Thanks!
