I have a 3-Phase AC Motor designed for opening an electrical sliding Door, with Electromachanical and Infrared in my design. The problem I have is in the controlling circuit. Since the motor operating Direction varies by shifting the Phase on Electromechanical Releay to Electro motor, it won't work when someone activate the Infrared by crossing the door while motor is working because the infrared warn the circuit and releay disconnect the electricity completely. I need some suggestion if I can replace the Electromachanical Releay in my circuit or if there is a solution.
I really appreciate your helps.
Regards
Sadra M.
Regards
Sadra M.
