Controlling 230 V pump using arduino
Discussion in 'The Projects Forum' started by Jeyasuriya, Mar 3, 2016.
  1. Jeyasuriya
    Feb 3, 2016
    8
    hello all..I am using an aquarium pump (230V) to pump water to a height of one and half meter..i want to control this pump using my arduino..kindly help me with interfacing both..Thanks in advance
  2. Dodgydave
    Jun 22, 2012
    5,143
    768
    You need to use a relay with a 5/12V coil, and contacts rated for 230Vac 5amp.
  3. TheButtonThief
    Feb 26, 2011
    219
    38
    What exactly are you hoping control? Do you simply want to turn the pump on and off automatically or do you want to control it's speed too? If you're going for automation, are their inputs to be concerned about? Sensors, limits, push buttons...? How big is the motor in the pump, how much current does it draw? Is their any long cable runs we should know about? Is the solution required to be submersible? Are you looking for a modular solution or are you ok with discrete components?
    We need more info before we can help.
    Cheers
  4. Jeyasuriya
    Feb 3, 2016
    8
    Thankyou it was helpful
  5. Jeyasuriya
    Feb 3, 2016
    8
    i just want to on and off my pump automatically..the solution needn't be submersible...i am not sure of the motor size in the pump...it draws a power of 45W operating in 230V 50 Hz supply...I am okay with discrete componets...Thanks in advance
  6. mcgyvr
    Oct 15, 2009
    4,787
    973
    Then as stated by dodgydave you just need a relay..
    This is the typical setup for an arduino driving a relay..
    http://playground.arduino.cc/uploads/Learning/relays.pdf
    There are thousands of examples on the internet.. Just google "arduino relay" and have fun..
  7. Jeyasuriya
    Feb 3, 2016
    8
    thankyou..it was helpful :)
  8. TheButtonThief
    Feb 26, 2011
    219
    38
    Except it's not just a relay he needs, he said he needs a way of controlling the pump automatically, so sensors too...
