Controlling 20V path from 5V
Discussion in 'General Electronics Chat' started by safia, Jan 26, 2016.
  1. safia
    May 29, 2013
    11
    Hi ,
    I would like to pass/stop 20V (2MHz)switching signal using 5V in cadence. as shown below with stand alone switch and its application to buck converter in two way switch.
    5V control is selectable: it should enable one path at time if we select 5V and other when 0V is applied or any other scheme can be suggested. highvolcontrol.png
  2. crutschow
    Mar 14, 2008
    13,475
    3,362
    You explanation is confusing. o_O
    What "5v control" are you referring to?
    What alternate "path" ?
  3. safia
    May 29, 2013
    11
    i mean using 5V can we control 20V path. we can do using transmission gates if the path has a voltage of 5V also , but here is 20V
  4. PeterCoxSmith
    Member
    Feb 23, 2015
    148
    38
  5. Alec_t
    Sep 17, 2013
    5,968
    1,135
    Can't you simply use the 5v to enable/disable the driver?
  6. safia
    May 29, 2013
    11
    Actually, i want to desgin it from MOSFET level circuit in cadence or any other tool
  7. safia
    May 29, 2013
    11
  8. PeterCoxSmith
    Member
    Feb 23, 2015
    148
    38
    if you look at the Fairchild Mosfet drive datasheet that I linked to, there is a good block diagram of what you need to do to design your own driver, if that is what your aim is...
    safia likes this.
  9. crutschow
    Mar 14, 2008
    13,475
    3,362
    To control voltages greater than 5V you will need a MOSFET that has a power supply voltage also greater than 5V.
    Don't know of any way to control a voltage higher than your supply voltage.
