controlled switch
Discussion in 'General Electronics Chat' started by ROILEVI, Mar 11, 2009.
  1. ROILEVI
    Mar 11, 2009
    1. i want to built a switch (on/off) circuit .
    to controll with DC. voltage of 5v (from microcontroller).
    controlled curent 4-10 A / 220-240 V ac.
    i assume with triac and moc
    but don't know how?
    2. if i will use a simple relay can i simply connect the relay to the
    microcontroller or do i need a buffer or something ??
  2. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    If the micro-controller can source or sink the current needed by the relay, then no driver will be needed. The probability is you will need a MOSFET or Darlington to drive the relay.
  3. ROILEVI
    Mar 11, 2009
    i have got a 8051 microcontroller.
    should i connect the relay directly to the output port?
    or maybe to the dac ?
    i'm afraid of current leakage form the relay or something that will
    burn the micro...
  4. gotumal
    Mar 24, 2008
    99
    8051 is a generic series. What is a specific part no, so that we would know the sourse/sink capacity of pin. But as thingmaker3 said, you probably will need a transistor to drive the relay. Don't forget to put a free wheeling diode across relay (to protect transitor and probably a microcontroller).
    P.S. : You also need to be sure about the state of µc pin after resetting to avoide chattering of relay during power-up.
    All the best.
  5. ROILEVI
    Mar 11, 2009
    can i use a moc (photo)"moc3041" and a triac (BTA12)??
