I´m working on an ethernet switch, the basic setup goes like this: PHY - differnetial mircostrip - transformer - diff. microstrip - connector (see attached image)
I have a ground plane underneath the lines going from PHY to transformer, but I am struggling with what should the plane on the other side of the transformer be connected to. Would it be the point between R1, R2 and C9?
Does the plane even need to be connected to something, isn´t the presence of a metal plane enough to create the differential impedance between the two data lines?
