Controll VGA with encoder.
Discussion in 'Embedded Systems and Microcontrollers' started by Rosi, Dec 14, 2009.
  1. Rosi
    Dec 14, 2009
    Greetings all.
    This is my first post in the forum and I do not know even if I have posted in the correct place.
    I start doing a small project with a FPGA and VHDL I searched around found couple of solutions but I am not happy about them.
    So here I am asking the question to experts :)
    I have to make the pong game. Old classic one. I was asked to make the side bars move up and down (two of them) using encoders.
    So I need to create the bars first and then to control them with encoders.
    Until now my solution was that I create a circlet the two encoders they are connected to the pins 18-17 and 16-15 of a FPGA. I used the input of them as feedback but it didn't really work. I had to format my computer either case so I said that I can start a new with better solution.
    If you know any good tutorial or link or book something that can help me out, please advance :)
    Thank you
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. Rosi
    Dec 14, 2009
    Thanks for your answer.
    Well it was kinda weird way to start the project. It is a Univ project so hardware is not an issue. I asked the professor and he gave me encoders. rotary encoders 265-1723. I was kinda happy to see that I asked for the correct ones (even before reading your answer).
    I even manage to put some code in the VHDL. I can share if you want to and try to improve it.
    I still have some troubles to figure out how to insert the value from the encoder in a registry.
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Use it as a count that translates to absolute position. Use the quadrature outputs to determine if the count goes up or down.
  5. Rosi
    Dec 14, 2009
    Hello again :)
    Once again, first do it and then read your answer :)
    But either case it is working so I am happy. I will keep asking question if I come up with something that I can not figure out (which would most likely mean that I simple need to spend a bit more time on it)
    In any case thanks for your feedback so far :)
    Rosi
