controling sound-card output
Discussion in 'Programmer's Corner' started by Liad, Aug 12, 2007.
  1. Liad
    Aug 10, 2007
    5
    Hey!
    I need to control the sound-card outputs using [preferably] C#.
    How do I contol different channels [in a 5.1 sound cars]?
    How can I control the output voltage, freq. and time?
    Liad.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The sound card should have some information from the manufacturer about sending data to the individual channels. If not at a hardware level (which registers to address), then how to send it through the driver for the card.
    The output is from a digital to analog converter. if 16 bit, then the magnitude of the sound will be dependant on a value of 0 to 65767 decimal. Do some reading on the sunbect of d to a converters for an answer to the frequency question. You will be making a file of numeric values that will be sent to the sound card. The contents of the file will control the output in frequency and anplitude.
    If I interpret your question about time as distinct from frequency, the intervals between your non-zero values will control the timing between outputs. - or you can send the smame file over and over, with intervals between the transmissions to establish timing periods.
