Control two DC motors with a PIC
Discussion in 'Embedded Systems and Microcontrollers' started by Tengil, Mar 12, 2007.
  1. Tengil
    Mar 11, 2007
    Hello again :)
    I would like to control two LEGO motors (the powerful model) through a PIC. I'm not quite sure if it will be necessary to control the speed. I'm going to connect the engines to some tank-like tracks. I hope it will work with just full forward or reverse, but if it won't make the movement smooth enough I suppose I could use some sort of PWM arrangement to control the speed.
    I'm not sure how to construct the motor circuit. I've found a schematic over a circuit that did something like this. However it looked very advanced to me, not the schematic itself but it used a lot of componentes (opto-isolators etc) which I don't have. I would like if there's some easy way to easily change the direction of the engine.
    * Do I really need an opto-isolator to make the circuit stable?
    * What the difference between a normal transistor and a FET when using it with a PIC and a motor? I only have normal transistors right now, do I risk burning my PIC if use them?
    * How would the circuit schematic look for this to be done? :)
    * Can a tank be done without speed control?
