control systems
Discussion in 'Homework Help' started by vvkannan, Jan 15, 2009.
  1. vvkannan
    Thread Starter Active Member
    Aug 9, 2008
    138
    11
    Hello ,
    Iam stuck with this question
    A second order system has a transfer function given by G(s) = 25 / (s^2+8s +25).If the system initially at rest is subjected to a unit step input at t=0,the second peak in response will occur at ?
    using inverse laplace transforms we get the response as
    y(t) = 1 - 0.6(exp(-4t) sin(3t + 37))
    From this we have a formula to find the time taken to reach the first peak but i dont know how to find the time taken to reach second peak
    Thank you
  2. KL7AJ
    Nov 4, 2008
    2,047
    295
    How's 2t work for ya?
  3. mik3
    Feb 4, 2008
    4,846
    63
    The first positive peak will occur after 1.35 sec and the second positive peak after 2.01 sec of the first peak. It's the time the first peak needs to occur plus the time of the period of the sine wave.
  4. vvkannan
    Aug 9, 2008
    138
    11
    Thank you mik3.But how did you find first peak?
    Using the formua Tp = 3.14/damped frequency i get 1.047 seconds for peak time and plus time period gives the time of second peak as 3.14seconds
    sorry KL7AJ i cant understand what you mean
  5. mik3
    Feb 4, 2008
    4,846
    63
    The first peak will occur when the angle in the sine is 270 degrees (sin(270)=-1) but because it has a phase shift of +37 the angle becomes 270-37=233. In rad is 4.06, you know the angular velocity which is 3 rad/s and thus the time t is:
    ωt=φ thus
    t=φ/ω=4.06/3=1.35
    where
    φ=angle in rad
    ω=angular velocity in rad/s
  6. vvkannan
    Aug 9, 2008
    138
    11
    Thanks mik3 but isnt pi/damped frequency the general procedure to find the peak time ?.Moreover the answer given is 3.14 seconds which we dont get when peak time = 1.35 seconds.On the other hand we get the same answer if we use the formula
  7. mik3
    Feb 4, 2008
    4,846
    63
    I don't know about this "pi/damped frequency". Which answer is 3.14?
  8. vvkannan
    Aug 9, 2008
    138
    11
    The final answer (i.e) the time at which the second peak occurs.
