control system question no (see the attachment)
Discussion in 'Homework Help' started by hilal7707, Apr 24, 2011.
  1. hilal7707
    Apr 24, 2011
    5
    please help me to solve this homework :) :) :)
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    This might give you a start.
    You should then make a contribution ....
  3. hilal7707
    Apr 24, 2011
    5
    Thank you T N k
    I want to solve it with details because i want to learn from you and others so while you solve it please do it slowely with full explenation.:)
  4. t_n_k
    Mar 6, 2009
    5,448
    783
    The information I posted should at least allow you to complete part (a) of the question.
    If you can't do this then you unfortunately appear to have limited understanding of some important basic ideas on control theory and transfer functions.
    Please try to use what I gave you to solve part (a). There is an expectation that when you post in the homework forum you show some attempt at a worked solution.
    Make that attempt and you will probably get some ongoing help - otherwise you may not.
  5. hilal7707
    Apr 24, 2011
    5
    very nice,
    see the attachment
  6. t_n_k
    Mar 6, 2009
    5,448
    783
    Hello hilal7707,
    Your algebra has let you down. Check the attachment.
  7. hilal7707
    Apr 24, 2011
    5
    sorry because i working and studing + i donot have scanner
