It would help if you first give some detailed thought to WHAT exactly do you want this 'control system' to control.
Secondly, very important is to consider what parameters you need to monitor in order to implement the control functions you have decided on.
Like for instance, do you want to control azimuth, elevation angle? Or do you mean you want to control the output of the panel to perform some function? If so 'What function'?
You have to define it before we can help you. So put your thinking cap on and take some notes. Then post your notes.
