Control RPM motor
Vindhyachal Takniki
Joined Nov 3, 2014
594
1. I have to control the rpm of motor. There is feedback in pulses by which I can see what is the rpm of motor.
2. I am planning to do it by phase control.
a. Read PWM signal of motor for 1 sec.
b. Calculate the speed
c. control the phase.
d. go to step a.
3. I am not able to control phase precisely. RPM of phase shows variation of +-40 rpm then what I set.
4. What I have noticed is even if I give constant voltage 220vac directly, even then the rpm/pwm keeps of changing.
5. Any other precise method to control rpm of motor. Motor runs on 220Vac. Its shaded pole motor
MaxHeadRoom
Joined Jul 18, 2013
28,688
Need more circuit details, what do you mean by 'PWM signal of the motor' ? Also a shaded pole 1ph AC motor is not a really good candidate for motor control.
Max.
