I have a 5-Pin 30A relay, which I want to control from an AC 240V Source.
I have a transformer, 240 to 12VAC and this DC converter.
Problem is when I switch the power on, relay turns on and when I switch off its goes to back position, but on switching the power again the relay does not work. I have to remove the wires and then connect the wires, again it starts working.
What could be the problem? Relay works perfectly fine but only for the first time.
