Here is the code:
very very short and simple, yet all that comes up is a bunch of "&"'s, and at that only when the output is inverted. With it set to true, I get nothing. porta.0 is an LED to tell me when the next string is sent, portc.4 is the LCD. I've tried a half dozen ports, my baud rates are correct, checked a dozen times, set configs in programmer, everything works except the data doesn't go through. I've been using this chip to read/write an i2c eeprom, it works fine. Any ideas?
Yes I know my code is bad, it's just to test the connection before I add the LCD to a real program.
Rich (BB code):
define osc 4
INCLUDE "modedefs.bas"
do
high porta.0
high portc.4
pause 100
serout2 portc.4, 24972, ["abcdefg"]
low porta.0
pause 500
loop
