I built the following voltage regulator and do not have as fine as control as I would like. First I used a regular 1 turn pot, then a 10 turn pot but when I turn the pot, the numbers jump 2 or 3 hundredths of a volt at a time. The 10 turn pot is a 10K pot instead of the 5k pot that the circuit called for but I tried it a couple of ways;first with a 10K ohm in parallel which made it a 5k pot like the circuit called for, then at the 10k rating. Still no change. It still bounces around. Am I asking too much to have the numbers change with more control?
CJ
CJ
