control motor speed with byte
Discussion in 'The Projects Forum' started by Gadersd, Jul 15, 2013.
  1. Gadersd
    Dec 8, 2012
    98
    For my next project I am going to use a microprocessor to control the speed of four motors. The microproccessor will output a byte representing the speed of a motor. I need a circuit that will take a byte and either change the voltage or current to the motor to control its speed. I first thought of feeding the outputs of the microprocessor into a bunch of different sized resistors with diodes and connecting them together to control the current that goes to the motor. I might post a schematic of this later. I am pretty sure this is not the best way to do this. Any ideas?
  2. crutschow
    Mar 14, 2008
    13,475
    3,361
    You can use a D/A converter to convert the digital signal to a voltage. The voltage can then control the motor current or voltage, whichever you want.
    D/A's are available in many different number-of-bit resolutions. If you only are outputting one byte, then an 8-bit D/A would suffice.
  3. shortbus
    Sep 30, 2009
    4,088
    1,670
  4. tubeguy
    Nov 3, 2012
    1,157
    197
