Control current with arduino for testtool for explosion sensor
Discussion in 'General Electronics Chat' started by Jef Van Gorp, Sep 24, 2016.
  1. Jef Van Gorp
    Sep 24, 2016
    I need to create a small testtool for explosion sensors. These sensor uses a BPX 61 photodiode.
    I want to control the intensity of a 3 mm led with an arduino nano. But I can't directly use the PWM signal because my photodiode sees also a blockwave. The current through the diode must be constant but I need to be able to adjust the current so the intensity changes. Does anyone have an idea?
    Thanks,
    Jef
  2. Veracohr
    Jan 3, 2011
    559
    77
    If it can't be PWM use a DAC with a resistor to drive the LED.
  3. Alec_t
    Sep 17, 2013
    5,977
    1,136
    Welcome to AAC!
    Use a low-pass filter to smooth the PWM, then use the resulting DC voltage to drive a constant-current source.
