You can use this setup, which is similar to another thread where I uploaded this diagram.... but this is how the AC side should be connected...
Never mind the transistor on the input, this was for another application where a microcontroller controlled the SSR, you just need the AC wiring side....
Ran a quick test on the SSR this evening and it worked as it was supposed to. I just didn't realize that I couldn't check the resistance similar to a physical relay with contacts...
I'll make a more permanent solution later this week and finish my project.
