control a latching relay with one switch?
Discussion in 'General Electronics Chat' started by anne, May 27, 2008.
  1. anne
    Thread Starter Active Member
    Apr 20, 2008
    39
    asdasdadassdas
  2. Caveman
    Apr 15, 2008
    471
    There is a way, but I've got to try to remember, it basically involves passing the current back and forth through a capacitor. I'll try to get back to you within the day to let you know if I remember.
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Single coil is the only one that will work with one switch. How much of a load are you switching? I've been using a P & B 12 volt latching relay to run a set of lights in my basement for 8 years. From 5 locations, at that (all the pushbutton switches are in parallel).
  4. Pich
    Mar 11, 2008
    119
  5. anne
    Apr 20, 2008
    39
    asadasadssadsadsa
  6. KMoffett
    Dec 19, 2007
    2,584
    234
    Here's a push-on/push-off circuit with a standard-relay that I always considered slick. :)
    http://radiomagonline.com/notebook/radio_pushonpushoff_switch_2/
    The main criteria is that the DC supply voltage is twice the coil voltage (24v for a 12v relay...12v for a 6v relay...~9v for a 5v relay), and R1 = R2 = Rcoil. You can play with the capacitor for physical size vs. reliable operation.
    Ken
  7. anne
    Apr 20, 2008
    39
    asdfasdasaasda
  8. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Check the Potter & Brumfield S89R11DAC1-12 impulse latching relay. It changes state with each application of voltage - no polarity reversal needed. It's goo for 15 maps @ 120 VAC. A momentary pushbutton switch is all it needs, along with the coil voltage.
    I see your problem now. These are way too big for your application. You may need to use KMoffett's trick.
    Another thought - if this is a weenie DIP relay, you might think about using a flip-flop that is toggled by the switch. Each debounced press of the switch toggles the flip-flop to the next state, supplying of cutting off current to the relay coil.
  9. anne
    Apr 20, 2008
    39
    qweqweqweqwqqeeqewqe
  10. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Hello Anne,
    Have you considered push-on, push-off switches to control the relay's coil?
    Since the length of the button's exposed shaft changes, you really wouldn't need a lit indicator - unless you wanted to be able to observe it while wearing a welder's mask. A small LED with a suitable current limiting resistor would serve in that regard.
    Ebay auction:
    http://cgi.ebay.com/10-Miniature-DP...oryZ4660QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
    You could use this switch to control the coil of a low-voltage relay. This one is DPDT; each contact rated 100mA @ 30v
  11. gerty
    Aug 30, 2007
    1,154
    304
    I wouldn't give them a second thought, if people don't like my question, it's their problem not mine. Sarge's fix seems to be the easiest..
  12. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Quite a bargain!
    The problem with using flip-flops is that they would "forget" their logic state when the power was turned off.
    An example of a Dual-D Flip Flop would be a CMOS 4000-series 4013, or CD4013B (many different manufacturer part numbers), a J-K Flip Flop would be a 4027 (CD4027B) etc. But, unless you kept them supplied with voltage, they'd "forget".
    Everyone's been there at least several times. If they deny, they lie. ;)
  13. anne
    Apr 20, 2008
    39
    wqerwerwqewewerwe
  14. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The short answer is no. The contacts will burn with too much current, and they may not separate enough to stop arcing with 120 VAC applied. You may have to consider a solid state relay to keep package size down. You could use a pushbutton switch, but it would have to be alternate action (maintained contact).
  15. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    The type of switch I posted is in common use on items like test equipment (oscilloscopes, frequency counters, etc.) No, it would not be suitable for 120v switching, but would be for 24v, 12v, 6v, 5v, etc. I do know that Skycraft Surplus has (or had) in stock some VERY small 120v to 6.3v or 7.5v transformers, which might be used to supply current to this switch, to power a relay's coil. I do not recommend running a component at it's maximum ratings, as it's lifespan will be considerably diminished.
    You seem to have your mind set on a switch-controlled relay. Would it be possible for you to consider something like a micro SPST, DPST, or DPDT toggle switch? Sometimes the simplest route is the best.
    I don't know if this is the same project you were working on before, but I suspect that your space constraints are rather tight. Cost is always a factor.
    Those tiny latching relays you found seem rather promising. Price is right, too.
  16. Wendy
    Mar 24, 2008
    20,772
    2,540
    That same low power switch could handle a Solid State Relay also, which are pretty easy to use.
  17. anne
    Apr 20, 2008
    39
    qwreqweqweqweqe
  18. anne
    Apr 20, 2008
    39
    XXXXXxXXXXXx
