control a 3 phase 48 volts ac motor
Discussion in 'General Electronics Chat' started by sujinvipin, Aug 18, 2011.
  1. sujinvipin
    Aug 18, 2011
    28
    How to control a 3 phase 48 volts ac motor by a dc supplied inverter?
  2. strantor
    Oct 3, 2010
    4,302
    1,989
    never seen a 3 phase 48V motor
    you want to build an inverter? I think it would be more cost effective and time effective for you to buy one that has DC bus terminals.
  3. praondevou
    Jul 9, 2011
    2,936
    489
    You can do it with a microcontroller that can provide 3x 120 degree phase shifted PWM signals (sine wave modulated), pass them to 6 IGBT drivers and then to the IGBTs and then to the motor. No big filter necessary, your motors inductance creates the sine wave current. Also, you need a rectifier to create your DC-bus voltage...If there is load on the motor you need also a circuit to keep the DC-voltage low in case you decrease the motor speed, it will work as a generator increasing your DC voltage unless you can feed the energy back to mains, so you need to burn this energy in a resistor.
    The PWM also needs to be programmed to increase the current through the motor gradually (in a ramp).
    You see, it's complex.
    If you are a beginner don't try to build one... buy one :D That's a big project.
