can we do that with PFC+LLC circuitDiscontinuous mode flyback have the property the auxiliary outputs track the main (regulated) output fairly well between tightly coupled windings. But should still expect a 5% regulation tolerance.
Is this circuit for control both output can work?You can't do that.
You can only regulate one of the outputs with the control loop.
Sometimes the second (unregulated) output is made to be a slightly higher voltage than desired and an LDO linear regulator is used to drop it to the desired voltage.
The circuit would appear to work on the average voltage of the two outputs.Is this circuit for control both output can work?
I miss vref in one of the error amp, both has negative vref
so if the output 24 on each output the regulation could be 5%? I need my output to be 24+-5%.The circuit would appear to work on the average voltage of the two outputs.
So neither output will be exactly regulated.
Is regulating to the average of the two output voltages sufficient for your purpose?
I don't know what the regulation would be.so if the output 24 on each output the regulation could be 5%? I need my output to be 24+-5%.
Can i use buck converter in both output ,so in this case i can control the 2 output, and is it is possible that efficiency will be more than 90%?I don't know what the regulation would be.
It depends mainly upon the transformer output winding resistance and the relative current load difference between the two outputs.
Certainly you can use two separate converters, but whether they are buck or not depends upon the input and output voltages.Can i use buck converter in both output ,so in this case i can control the 2 output, and is it is possible that efficiency will be more than 90%?
How can i make my efficacy higher than 90%Certainly you can use two separate converters, but whether they are buck or not depends upon the input and output voltages.
Thanks so much, is good for 200W, i need two output each one 24Vdc .100wThe usual way is to have a secondary post-regulator fed from a voltage a little higher than the desired ouput.
The simplest would be a synchronized buck. Unitrode (now part of Texas Instruments) used to have controller ICs precisely for this application.
by Aaron Carman
by Jake Hertz
by Jake Hertz
