contrast Sensor
ravizanwar
Joined Oct 11, 2009
5
Dear Friends
I need to develop the contrast sensor for my application as goes below
There is a white paper with chop mark square width 1mm and length 24mm i want to detect this chop mark .
Roughly the paper becomes little transperent at this chop mark.
Can u giuide how should and what concept whould i adapt.
bertus
Joined Apr 5, 2008
22,270
Can there be a light on one side and a detector on the other side?
Or must the light and detector be on the same side?
Greetings,
Bertus
bertus
Joined Apr 5, 2008
22,270
Here are two examples of "slotted" opto-interupters.
The MOC70P , with a transistor output.
And the OPB917 , with a logic output.
(see PDF's).
Both can be obtained at digikey.
Greetings,
Bertus
ravizanwar
Joined Oct 11, 2009
5
Dear
Thanx for your prompt reply but can u suggest me the second configuration in which transmitter and reciever both are different this will be suit to my machine mechanically very well.
Any standard ckt can be made with IR transmitter and reciever with potiometer for adjusting wavelength.
