(I am new, First post)
I have a similar project that is a continuous nodding/tilting head which uses a 24vdc motor and two 3 pole limit switches. As the unit tilts, a limit switch is eventually triggered momentarily, and the motor should reverse direction until the other limit switch is triggered. I have read many posts on the subject, are there any readily available (retail) pwm controllers that can take the limit switch pulse and continuously reverse the direction?
