continuous display on seven segment
Discussion in 'The Projects Forum' started by hassi, Sep 6, 2014.
  1. hassi
    Mar 1, 2013
    18
    hello,
    I want to display countdown on seven segment but I don't know the method to do it... Please help me...
  2. MrChips
    Oct 2, 2009
    12,636
    3,455
    Well, give us a hint as to what you are attempting to do.
    What seven segment displays are you planning on using? LED? LCD?
    Common anode? Common cathode? Current, voltage rating?
    Power supply voltage and current rating?
    How many digits?
    Frequency of count down rate?
    What number are you starting and ending in the count down?
    What are counting down?
  3. hassi
    Mar 1, 2013
    18
    common cathode
    does it work on 5V?
    count down - 9-0
    frequency rate - 1digit per sec
    only one digit can be displayed at one time on seven segment display
  4. MrChips
    Oct 2, 2009
    12,636
    3,455
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Is this an assignment from a teacher/instructor/professor as homework?
    Small LED 7-segment displays generally will operate from 5v or even less, but large LED displays may have multiple LEDs in series internally, thus need higher voltages before they will illuminate.
    Common-cathode displays require that you source current to the a thru g segment input pins to output light.
    Are you planning on using 74-series TTL components, 4000-series CMOS, or perhaps a microcontroller?
  6. hassi
    Mar 1, 2013
    18
  7. hassi
    Mar 1, 2013
    18
    through microcontroller
  8. shteii01
    Feb 19, 2010
    3,507
    512
  9. hassi
    Mar 1, 2013
    18
  10. ISB123
    May 21, 2014
    1,240
    531
  11. shteii01
    Feb 19, 2010
    3,507
    512
    I would take a uC like Arduino board and write a program to do the count. It is a bit of overkill, but from where I sit, it is the easiest to do.
  12. MrChips
    Oct 2, 2009
    12,636
    3,455
    hassi and absf like this.
  13. hassi
    Mar 1, 2013
    18
    thanks everyone..
