Continues Servo motor controller HELP
Discussion in 'General Electronics Chat' started by bryjosh316, May 12, 2014.
  1. bryjosh316
    May 12, 2014
    How to make a controller for my converted servo motor to continues rotation
    so that i can control the speed and forward/reverse of the motor,(no programming)
    i researched online and i found out about the lm555 timer IC but the two functions i want is made with two different circuit. i want to be able to use it in one circuit..
    looking forward for your help
  2. djsfantasi
    Apr 11, 2010
    2,900
    870
    Continuous rotation servos (hobby RC servos) are controlled in the same manner as a standard servo. Pulses of varying widths are applied every 20ms. These pulses vary from ~1300μs to ~1700μs.
    * 1300μs rotates clockwise
    * 1500μs stopped
    * 1700μs rotates counterclockwise
    To modify the servo speed, intermediate values of the pulse widths are used. For example, a width of 1475μs rotates the motor clockwise slowly.
    The following link describes this with a picture as well:
    http://learn.parallax.com/KickStart/900-00008
    This can be done with two 555s. The first 555 is wired as an astable oscillator running at 50Hz. It triggers a second 555 wired in monostable mode. A pot is used with this portion of the circuit to vary the pulse width. One such circuit can be found on the Seattle Robotics Society site.
    http://www.seattlerobotics.org/encoder/200210/servoex/ServoExcerciser.htm
    Hope this helps.
    bryjosh316 likes this.
  3. bryjosh316
    May 12, 2014
    any other way or better yet circuit diagram for the function i want
  4. djsfantasi
    Apr 11, 2010
    2,900
    870
    The second link I provided has the circuit diagram.
  5. MaxHeadRoom
    Jul 18, 2013
    10,827
    2,495
    Is this RC or an industrial servo?
    Both typically have very different types of control.
    Max.
  6. djsfantasi
    Apr 11, 2010
    2,900
    870
    Yes! I did specify hobbyist RC motors in a previous post.
  7. MaxHeadRoom
    Jul 18, 2013
    10,827
    2,495
    My question was to the OP, he did not specify? ;)
    Max.
    djsfantasi likes this.
  8. bryjosh316
    May 12, 2014
    yes its RC servo sorry for not being specific
