what the form equation of h(t) which make output y(t) if we have input x(t) ,h(t) is a linear time invariant system
thanks
thanks
no i did notHave you studied convolution in class?
but it will be taught in classno i did not
can i solve it without using convolutionbut it will be taught in class
Maybe someone else has a better idea, but you could write x(t) and y(t) in the time domain (in terms of t), take the Laplace transforms to get X(s) and Y(s), divide Y(s) by X(s) to get H(s), and then take the inverse of the Laplace transform to find h(t). After you go through that process, you'll find out why convolution is so nice to use in this case. Often times Laplace transforms are the best approach. Here I'm not so sure. I am assuming you've studied Laplace transforms, but maybe not.can i solve it without using convolution
by Jeff Child
by Aaron Carman
by Duane Benson
by Aaron Carman
