My car's sunroof is showing quite a bit of what at first glance appeared to be watermarks.
But that is not the case. It is quite possible that they're comprised of pine resin and some other contaminants that I've been unable to identify.
I tried to clean them up with a sponge soaked in white vinegar, to no avail. (Although that did work when I cleaned the windshield). Next, I'll try rubbing some baking soda on it, and see what happens. But I suspect that won't work either.
What should I do? Using muriatic acid seems a bit risky and unsafe.
@GopherT, I suspect you may be able to give me a hand here. Thanks.
