contactor
Discussion in 'General Electronics Chat' started by muganga, Apr 12, 2006.
  1. muganga
    Apr 12, 2006
    hi...i need help about how simulate a seal's circuit (contactor + 2 Pushbutton(START and STOP). My circuit is to start a motor...i tried simulate but when i push START..it didnt keep close. I am usind electronic work bench
    thanks so much...if you can add at MSN to exchange information about EWB i'll thanks a lot.
    Fernando Azevedo
    mugangalinux@hotmail.com
    Brazil
  2. windoze killa
    Feb 23, 2006
    605
    24
    You probably need to change the type of switch from momentary to On-Off latching.
  3. Papabravo
    Feb 24, 2006
    10,340
    1,850
    You put the sealing contact in parallel with the normally open START switch. These two switches are in series with the normally closed STOP switch. This is in series with the coil. This makes one ladder rung.
    The sealing contact should be a normally open contact from the same relay as the coil. When the coil is energized the normally open sealing contact in parallel with the START switch allows the START switch to open. Later whn the STOP switch is activated the current is removed from the coil which opens the sealing contact.
    Does that help?
