Hello, My cordless phone battery died a while back. I was going to go buy a new one but found it to be too expensive (!) So I thought why not make my own battery. Basically the specs of the original battery are
800mAh 3.6V NiMH
There are 3 cells in the battery each the same size as a AAA battery.
My idea was to use 3 Duracell NiMH AAA batteries and connect them in series (which gives the same voltage of 3.6 since each AAA battery is 1.2 volts) But the AAA batteries are 1000mAh not 800....does this make a difference. I was thinking it would not harm the phone, but rather give more talk time.
Does this make any sense, and will what I have suggested work? I just want to make sure I do not damage my cordless phone.
My other question is:
1. will there be any problems charging the batteries when using the original charger that came with the phone? (like overcharging)
thanks for reading and for any help
800mAh 3.6V NiMH
