constant torque
Discussion in 'General Electronics Chat' started by wes, Jan 5, 2008.
  1. wes
    Thread Starter Active Member
    Aug 24, 2007
    242
    are there any motors that are able to maintain a constant torque no matter the rpm . so say it runs at 5000 rpm no load and 5000 rpms under load because the torque doesnt decrease with speed increase or decrease and pulls the same amount of power
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Read up on pulse width modulation. That is the technique used to maintain nearly constant torque over the whole range of DC motor speed.
    AC motors can be controlled over a range of speeds with nearly constant torque using a variable frequency drive to essentially make a simulated AC waveform.
  3. Ron H
    Apr 14, 2005
    7,050
    657
    Power output is defined as torque times rotational speed. Since input power is proportional to output power, then at fixed RPM, the input power will change as the load changes.
  4. h.d
    Oct 22, 2007
    150
    you ask about motor with constant torque at variable speed or constant speed at variable torque?
    if you mean constant speed (5000rpm at noload and 5000 rpm at loaded)
    you should use syncronous motor which is AC-motor
  5. shankbond
    Nov 4, 2007
    53
    my friend i believe that ,if there is load on synchronous motor then it draws more power,which is not desired .:rolleyes:
  6. scubasteve_911
    Dec 27, 2007
    1,202
    I'm confused... Do you expect mechanical power for free? Of course the electrical power demand will increase! Synchronous AC motors do run at a fixed speed by design and will try its best to maintain it under load,.
    Steve
  7. wes
    Aug 24, 2007
    242
    alright thx for all the input
  8. Papabravo
    Feb 24, 2006
    10,338
    1,850
    Every set of DC motor performance curves shows the torque going to zero at some speed. This is entirely different from the minimal torque required to keep a motor going at a constant speed within its range.
