Constant Current Source
Discussion in 'The Projects Forum' started by Ishaan Karnik, Jun 15, 2012.
  1. Ishaan Karnik
    Jun 15, 2012
    I am supposed to develop constant current source (sub-part of the project).
    The catch is that the current source is to be of 100 Amps., 5-15 Volt Output with analog dimming.
    Input can be 5-24VDC or 240VAC(Wall Supply).
    I have found out that such power supply exist but we not to buy them.
    Any ideas fellow.
    Regards,
    Ishaan Karnik.
  2. Dollarday
    Member
    Jan 25, 2012
    32
    Hi Ishaan,
    Are you sure the output is 100 Amps (Not milli-amps)? That sounds a bit hectic...
    Regards,
    Hermann Havenstein
  3. Ishaan Karnik
    Jun 15, 2012
    Hermann Havenstein,
    Yes, I am sure that its 100 Amps. and not 100 Milli-Amps with 5-12 Volts output (15Vmax).
    Its is to be used on a high constant current load. Analog dimming/control to control current output is preferred.
