CONSTANT CURRENT SOURCE WITH DIGITAL POT
Discussion in 'The Projects Forum' started by ramana.madishetty, Oct 30, 2014.
  1. ramana.madishetty
    Jun 11, 2014
    12
    Hello every one.
    Need a suggestions on constant current source with 1 mA to 500 mA range using a Digital Potentiometer.
    Precision is 1mA difference.
    Please view the uploaded file. the circuit is somehow am modifiy to the range of 1mA to 500mA range using Digital pot.
    Present am using analog pot where am unable to change the output in the required range.
    How can i set to the range of 1mA to 100mA by modifying the circuit?????
    Please suggest on the circuit and also any other circuits will be appreciated.
    input= 12v
    current adjustment output= 1mA to 10omA
    Voltage adjustment output= 1v to 12v
    Precision current = 1mA difference
    Best Regards.
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    Seems overly complex.
  3. ramana.madishetty
    Jun 11, 2014
    12
    can i find any other circuit by using DIGITAL POTENTIOMETER for required outputs. Please suggest or provide any links.
  4. Alec_t
    Sep 17, 2013
    5,977
    1,136
    I don't see how your circuit can provide controlled current over a 1-100mA range, and certainly not with 1mA accuracy? The current flowing from the LM317 pin 2 to the load is not monitored.
  5. ronv
    Nov 12, 2008
    3,403
    1,477
    What is you load resistance?
  6. crutschow
    Mar 14, 2008
    13,505
    3,378
    If you need more precision with an analog pot, use a 10-turn type. Or add a second pot to provide a vernier adjust to the main pot (pot with smaller resistance connected as a rheostat in series with the main pot).
